Lian Li Tyr PC-X1000 Announced
"The latest in the Tyr Series from Lian Li is announced."
Published: 11th August 2009 | Source: Lian Li |
Today, Lian Li have added a third case to their Tyr range. The PC-X1000 is a full tower case that looks very similiar to the previous PC-X2000, just more refined with extra features. It has a total of 5 140mm fans, 3 intakes and 2 exhausts, meaning it should keep the computer both cool and quiet.
As you can see, the threee thermal zones are very clear and will help performance alot. The bottom section has a 140mm intake which allows the hard drives the be cooled, and cool air to be drawn into the specially designed L-ATX power supplies from Lian Li, which use a wider casing.It also has the new tool-less power supply installation which all
No pre-cut radiator holes? Tool-less card holder (that never work). Single PSU position. Shortage of exhaust holes.
Hmmm. Nice, but I think other cases have well overtaken them in usefulness.
VB
I don't know. I appreciate they always make quality cases, but they've really given up on the innovation. Or even copying. Or trying to be slightly different to their normal case.
VB
The PSU can also be mounted in the top if you remove the hard drive rack.
Continue reading
