External Hard Drive Enclosures: Rapid-Cases
"Sharkoon introduces a competitively priced series of external enclosures for 3.5" hard drives."
Published: 9th October 2007 | Source: Sharkoon |
Sharkoon introduces a competitively priced series of external enclosures for 3.5" hard drives. The new "Rapid-Case" series is available in black or silver and with several different connection interfaces. IDE hard drives connect via USB-2.0, while SATA hard drives have the option of two different models: one model with a USB-2.0 connection, and one model with both e-SATA and USB-2.0 connections. The simply designed Rapid-Cases are made of solid aluminium and ideally suited for flexible and portable use as they measure just 115 x 35 x 205 mm. Together with the included stand, the enclosure can also be installed vertically. The packaging includes a USB cable (A/B), power supply, stand, screw driver, installation screws, instructions and anti-skid rubber pads for the bottom of the enclosure.
More infomation on the enclosures can be found here.
Have anyting to say about these stylish hard drive cases? Please tell us on our Forums.
Hi,
im trying to find a gigabyte motherboard for my build
the version i am after is Gigabyte GA-P35-DS3R but has to be a rev 2.0 board (no parrallel or serial port )
have contacted gigabyte support who says these boards should be hitting the retailers at the end of september, can anyone tell me tekheads will stock these any time soon?
also seems like there are rev 2 versions of other gigabyte boards coming out as well, again without the parrallel port and serial port, as tekheads dont show the revision of their boards will they update their pictures of these boards to reflect the rev difference as it may well upset a few customers if they order a board (picture shows rev 1 version) and end up with a rev 2 board (which looks different to the rev 1 board) and visa versa
Anyone?
could someone from tekheads comment as to if current stock is rev 1 or 2 and if there are any plans to stock the rev 2 ?
