CoolIT Release Domino A.L.C Cooler
"With similar looks to the rest of the range but costing far less, it offers high end cooling to the masses."
Published: 18th December 2008 | Source: CoolIT |
Today CoolIT have announced a radical new water cooler which promising high end cooling for far less £££. The new cooler, named Domino A.L.C supports Intel sockets 775 and 1366 as well as AMD AM2+. Here is what they have to say about the Domino:
Domino’s Features and Benefits include…
* Simple Installation – Compact and light plug and play design with an innovative retention mechanism allows for quick installation into even the most crowded chassis supporting a 120mm fan. Domino ALC is universally compatible with Intel and AMD processors including Intel’s next generation Nehalem-based Core i7 processors
* Advanced Control and Configuration – Configurable options range from whisper quiet operation to extreme cooling for overclocking…all at the touch of a button. The micro-controller auto-regulates the system in all modes of operation to ensure continuous protection.
* Intuitive LCD Display – Conveys system status and issues a visual/audio alert notifying the user should the system require attention
* Whisper Quiet Operation – Allows gamers to hear their games…not the cooler
* Highly reliable – Advanced design and highly reliable components provides over 50,000 hours of maintenance-free quiet cooling
* Other Benefits – High efficiency design allows for minimal power consumption (8W max). Lightweight build places up to 70% less weight on the motherboard than heat sink/fan solutions thus removing risk of damage to vital components
You can view the full product page here.
Discuss in our forums.
it's not a great overclocker being apparently chipset limited.
I think that ~380fsb is the highest that I've ever seen reported.
Hmmm thought as much... it will be going soon... I cannot hit any higher than 360fsb...
Any good MATX overclockers you could recommend?
Thanks
Joe
Thanks
Joe
budget?
do you need IGP?
do you need IGP?
Around 100 pounds, can go more if needs be but would like to keep it as low as poss, sorry to sound a noob but IGP?
Joe
Joe
IGP: Integrated Graphics Processor - do you use the graphics built into the motherboard or do you have a separate card?
EDIT: Just seen you have a 3650 - you don't need a board with IGP then.
That board is a fantastic piece of kit. Sure it won't blow your mind overclocking, but it is a great board if you want an IGP
Oh Ok I thought it had something to do with Graphics but I wanted to check to stop any confusion. No I don't need IGP I have an ATi 3850HD GPU.
Any thoughts on a good board?
Joe
Joe
Thanks
Joe
