Aqua-Pcs becomes only UK distributor and reseller for CoolIT
"Aqua-Pc's has become the only UK destributor and reseller of CoolIT Systems' products."
Published: 22nd October 2007 | Source: Aqua-Pcs |
Riding high on their recent success at being named the Official Launch Partner for Blowfast cooling products , Aqua-Pc's has again usurped the competition by being named as the only UK distributor and reseller for CooIT Systems products.
CoolIT Systems' range of cooling solutions uses patented MTEC technology, and their popularity amongst PC enthusiasts is well known. Let's hear what CoolIT have to say about their products:
Specialising in a range of cooling solutions, CoolIT are particularly well known for their CoolIT Eliminator and Freezone products, and their highly anticipated CoolIT Elite. However, CoolIT also stock a considerable range of cooling accessories worthy of a home within your PC.
Want to see the range that Aqua-Pc's have to offer? Then head straight to their CoolIT product page here
Feel free to discuss CoolIT products with Aqua-Pc's here
Congratulations Aqua-Pc's on acquiring an exclusive UK distributorship and reseller license for CoolIT Systems' products.
Freezone CPU Cooler
Eliminator CPU Cooler
Ram Fan Cooler
PCI Cooling Booster
USB Beverage Chiller
Being fedex'd to us as we speak - we will have these in for testing next week, if all the unit meets our quality control and tests then we will be putting them in to stock at the end of the week :):p we have also insured the OC3D get Priorty review items so they can test these to :)
I can now confirm that we have the following:
Freezone CPU Cooler
Ram Fan Cooler
PCI Cooling Booster
Can you get me a new mounting kit - if I give you the correct part letter?
Sean
Should be no problem if you can get me the part number asap might even get it out tomorrow with the testing pack :p
You know that thing that happens when when you loose something, can't find it anywhere and then eventually give up and stop looking....
I found it
Sean
:rolleyes: :D
:rolleyes: :D
Hey thats the freezone elite isnt it!
Coolits rock, I am running a 1.56 volt to my cpu for OC testing and I am keeping the cpu at 56 degrees under load now. Thats alot of cooling for that amount of heat.
My thermal AS5 seated finally and shwoop! down went the temps. I ran prime 95 3 hours small ftts and it reached a max of 56 degrees on 2 and 48 on the others. Held just fine.
Looking forward to your results remember to give it a little bit for the thermal to cook. Keep us posted!!!
I do like the build quality of the stuff - very well made.
I havent been able to get an Elite just yet thats the bog standard Freezone and eliminator in the pics :D
Your going to love the stuff! I fiddle with mine and it rocks as well as theres a ton of different ways to do fan configurations in a case to make it more effective. Its not limited to "as it sits" It can be adjusted with case fans as well to lower temps.
Put it up and lets see some pics!!!! BTW nice site water boy!!! Very cool! No pun intended!:D
Would that help. The only problem - and one I haven't got around to fixing is that its missing one of the CPU mounting kits - the one for the C2D that I put in a safe place and never found again...
Sean
