Aqua-PC's Offer Value Aluminium case for £10.49!
"Fancy an Aluminium case with 1.2mm thick panels for under twenty quid delivered? Check out Aqua-PC's latest OC3D exclusive offer."
Published: 15th April 2008 | Source: Aqua-PCs |
Aqua-PC's offer value aluminum case for only £10.49!Most Recent Comments
Thanks for the help Kemp. ;)
SLI has now popped up. Damn Nvidia.
Oh well, cannot complain with an idea ram usage of 73mb. :)
Damn, Vista 1gb idle here?
So? It really doesn't matter tbh, Vista dynamically assigns RAM when it's needed and uses it for system idle processes when it's spare
So? It really doens't matter tbh, Vista dynamically assigns RAM when it's needed and uses it for system idle processes when it's spare
Word.
I'm close to 2gb usage :p but it doesn't matter because of the above point ;)
You can get SLI under Windows Xp Professional x64 Edition, though.
And since XP x64 SP2 is really just Windows Server 2003 R2 SP2 masquerading as a desktop OS, go use that.
Just be sure to use the 174.74 WHQL drivers or you'll have all sorts of wacky issues with it.
